[GRASSLIST:5012] RE: cvs login: warning: failed to open //.cvspas
s for reading: No suc h file or directory
Glynn Clements
glynn at gclements.plus.com
Wed Dec 1 04:54:51 EST 2004
Patton, Eric wrote:
> Ok, I've noticed something related to my last question that might be the
> problem....when I log out of Cygwin Grass 5.7, I get the following message:
> Closing monitors.....
> Cleaning up temporary files.....
> cp: cannot create regular file '//.grassrc57': No such file or directory
> Goodbye from GRASS GIS
> Where are those double slashes coming from? Is that a typical Cygwin error?
> I seem to recall there was a thread about double slashes ending up in
> directory and file paths under Cygwin, does anyone know about this error?
The error message is a result of the following command at the bottom
of etc/Init.sh:
# Save GISRC
cp "$GISRC" "$GISRCRC"
GISRCRC is set at the top of that file as:
GISRCRC="$HOME/.grassrc57"
This will fail on Cygwin if $HOME is "/", as Windows (and thus Cygwin)
uses the "//" notation for SMB network shares.
You should ensure that Cygwin sets $HOME to something other than "/",
typically "/home/<username>".
