[GRASSLIST:5044] Fwd: Re: Re: db.login
Leonardo Lami lami at faunalia.it
Fri Dec 3 08:19:42 EST 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Sorry but I retried it and the result is the some.
My VAR file is:
DB_DRIVER: dbf
DB_DATABASE: /home/Documenti/datigrass/Toscana/leo/dbf
GV_DRIVER: pg
GV_DATABASE: host=192.168.0.10,dbname=faunalia
GV_SCHEMA: prova
When I use v.in.ogr the table is stored in database faunalia schema prova.
If I change the VAR file in this way:
DB_DRIVER: dbf
...without GV_* options...
v.in.ogr say:
WARNING: Default driver / database for vectors set to:
         driver: dbf
         database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
and it put the tables in the dbf directory placed in the working mapset.
I can not understand it.
Bye
Leonardo
Alle 12:01, venerdì 03 dicembre 2004, hai scritto:
> > Hash: SHA1
> > Hi,
> > After the new command db.login and the remotion of v.database I have some
> > problem with the relocation of the table when I import vectors (like
> > shapes) in GRASS.
> > Grass put the table in the database setted in the options GV_* of file
> > VAR placed in the working mapset.
> > I see that the command db.connect change the DB_* options but not the
> > GV_* options.
> > How can I change the GV_* options and what about the function of the DB_*
> > options?
> > Thanks of all
> > Leonardo
> GV_* are not used, vector tables are stored in database defined by DB_*
> (db.connect).
> > About overwrite protection I think that it is very important to have a
> > flag to avoid delete the tables linked to a vector when I delete the
> > vector. What do you think about it?
> Almost impossible to add this flag to all modules. Why do you need that?
> Cannot you db.copy the table?
> Radim
Leonardo Lami
lami at faunalia.it            www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy   Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
- -----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBsFhh92hCyP73w7ARAgS0AJ9n/aSMYdmuRfQatEyaJ9CM4oemBwCfbXOp
G91Ws+RPXlf57nsD1IKQR7Q=
=WuVu
- -----END PGP SIGNATURE-----
Leonardo Lami
iD8DBQFBsGfu92hCyP73w7ARAiLBAKCjD5F1weoFfM5CBiSVD4gnOn66FgCdHRhk
/UFiieeF1PqcC4v8nJezUow=
=aAgU
