[GRASSLIST:5050] Starting a monitor
    Charles Rathbone
    c.rathbone at worldnet.att.net
    Sat Dec  4 14:36:37 EST 2004
I've installed GRASS 5.4.0 on an "emachine" running SuSE 9.1, but
can't get a monitor started.
When opening the Display Manager, an error message appears:
..."grassdata/spearfish/PERMANENT/.d.dmrc doesn't exist"
>From the GRASS menu, Display>Start Monitors>x0 causes a window to
appear and then immediately close, and then the following message:
    using default visual which is TrueColor
    ncolors: 65536
    Graphics driver [x0] started
    ERROR eof from graphics driver.
    Problem selecting x0. Will try once more
    Socket is already in use or not accepting connections.
    Use d.mon to select a monitor
Trying to select a monitor using d.mon generates the same result.
I will appreciate a suggestion on what to do next, or where to find
the solution myself.
Charles Rathbone
San Francisco, California
Voice & fax: 415-928-7347
Email: c.rathbone at worldnet.att.net
Taxis SF: http://c.rathbone.home.att.net
Taxis on the Internet: http://www.Taxi-L.org
