[GRASSLIST:5066] Re: width of geogrid lines in ps.map
    Ian MacMillan
    ian_macmillan at umail.ucsb.edu
    Mon Dec  6 19:08:47 EST 2004
I don't think you can do it straight from ps.map, but you could make
your own grid of vectors, then display that as lines and control their
width.  There used to be a v.mkgrid function, I am not sure if it is
still around anymore.
G'luck
-Ian
On Dec 6, 2004, at 3:34 PM, Brent Crittenden wrote:
> Grass folk,
> Is is possible to control the width of the lines that the geogrid
> function draws when using ps.map?  I am converting the ps.map
> generated postscript file to pdf via ps2pdf and then printing.  The
> printed geogrid lines are extremely thin and hardly noticeable.
> Thank you in advance,
> Brent
> RedHat FC2
> Grass 5.7
> DeskJet 810C
