[GRASSLIST:5119] Proper way to run 5.7 in batch mode?
Craig Aumann
caumann at ualberta.ca
Fri Dec 10 12:24:27 EST 2004
I presume running grass57 in batch mode is as described in "Open Source
GIS: a GRASS GIS Approach" p. 290 with a few obvious changes?
The problem is that I have written a whole bunch of shell scripts. When
I run the shell scripts individually my computer does load
balancing/sharing quite well.
grass57> ./script1.sh
However, if I call all the single scripts from a single script file, the
machine basically stops load sharing. e.g.,
grass57> ./callingscript.sh
where callingscript.sh contains the lines
#!/bin/bash
script1.sh
script2.sh
script3.sh
Sometimes, I can't even change workspaces. I'm running RHEL 3.0. I do
find this behavior very odd.
Cheers!
Craig
