[GRASSLIST:5164] Re: r.plane float value
Markus Neteler
neteler at itc.it
Wed Dec 15 02:13:22 EST 2004
On Tue, Dec 14, 2004 at 03:56:28PM +0100, ivan marchesini wrote:
> hi to all...
> r.plane works really well... also using floating point value for
> coordinates of the point the plain have to pass through....
> the problem is if you have to realize a plane not very dip....
> like 0.002... for example....
> r.plain accept only integer value for dip values and instead I need to
> use float values.....
> have someone some ideas about how to solve this prloblem???
> thank you very much
Solved in CVS.
Markus
