[GRASSLIST:5177] Re: db.select problem
grit grit.schuster at geographie.uni-freiburg.de
Thu Dec 16 10:03:21 EST 2004
Thanks Stephan!
this works fine using the grass prompt:
db.select table=corinelandcover sql='select * from corinelandcover
where BEREICH_NR=3 and GRUPPE_NR=31 and ART_NR=311'
echo "SELECT * FROM corinelandcover WHERE BEREICH_NR=3 AND GRUPPE_NR=31
AND ART_NR=311"|db.select
But, trying to run the same sql statement through the interactive db.select
user interface does end with an error:
db.select driver=dbf table=corinelandcover sql=echo"SELECT * FROM corinelandcover WHERE BEREICH_NR=3 AND GRUPPE_NR=31 AND ART_NR=311" fs=|| vs=-- nv=NULL
Sorry <*> is not a valid option
Sorry <FROM> is not a valid option
Sorry <corinelandcover> is not a valid option
Sorry <WHERE> is not a valid option
Sorry, <BEREICH_NR> is not a valid parameter
Sorry <AND> is not a valid option
Sorry, <GRUPPE_NR> is not a valid parameter
Sorry, <ART_NR> is not a valid parameter
I tried to use the "input=filename" option with the same statement. But in this case all records
of the table are selected.
I just don't understand it :-(
Grit
Stephan Holl wrote:
>Hello grit,
>On Thu, 16 Dec 2004 14:10:58 +0100 grit
><grit.schuster at geographie.uni-freiburg.de> wrote:
>>Hello,
>>could anybody please give me an idea about what I'm doing wrong?
>>I'm running db.select on the grass prompt with
>>Running the same sql query on db.select interative the following lines
>>are printed:
>>db.select driver=dbf table=corinelandcover sql='select * from
>>corinelandcover where BEREICH_NR=3 and GRUPPE_NR=31 and ART_NR=311'
>>fs=|| vs=-- nv=NULL input=/home/grit/sqlstatement
>>Sorry <from> is not a valid option
>>Sorry <where> is not a valid option
>>Sorry <and> is not a valid option
>Have you tried another syntax?
>This should do:
>Make sure, that the table is existent in your location/mapset/dbf-folder
>Cheers
>	Stephan
