[GRASSLIST:5187] Re: [GRASS5] New volume data set
    Huidae Cho
    grass4u at gmail.com
    Sat Dec 18 14:51:38 EST 2004
Sorry for my ignorance, but I cannot see anything even if I added
three isosurfaces:
Current: precip3d.500z50 at PERMANENT
Visualization Type: isosurfaces
Shading: Gouraud
level: 700	Use volume as color	transparency 100
level: 1000	Use volume as color	transparency 100
level: 1300	Use volume as color	no transparency
and clicked "Draw Current". Does 600-1300 mean threshold?
Thank you.
Huidae Cho
On Thu, Dec 02, 2004 at 12:56:45PM -0500, Helena Mitasova wrote:
> New data set for testing the GRASS5.7 volume support has been added
> to the GRASS Sample datasets (http://grass.itc.it/data.html):
> it includes Slovakia DEM and Precipitation data.
> You can get it directly from here:
> http://mpa.itc.it/grasstutor/data_menu2nd.phtml
> See sample visualization here http://grass.itc.it/grid3d/index.html
> (images on the top of the page)
> The volume visualization still needs some "tuning"
> so below are some hints how to make the images.
> Let us know if there are any serious problems
> (but read the below hints before complaining that you don't see
> anything)
> Helena
> Quick tour:
>  The map 'dem500' is used for a DEM.
>  There is a 3D file 'precip3d.500z50' that can be used
>  for isosurfaces and cross-sections.
>  nviz el=dem500
>  Then load the volume (Panel -> Volume -> New).
>  To see the isosurfaces use values between 600 and 1300
>  (e.g. 700 and 1000 with transparency of approx. 100 and
>   a third isosurface 1300 with no transparency).
>  Set the polygon resolution to 3 or less (note that for
>  resolution 1 you may need to wait a little depending on your
>  machine's speed) to render the volume.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
