[GRASSLIST:5220] v.in.ogr advice needed
Kirk R. Wythers
kwythers at umn.edu
Wed Dec 22 17:43:56 EST 2004
I have some shape files that I want to import into 57 and need some
v.in.ogr usage advice. The structure of the directory with the shape
files is thus:
barbaloot:~/Desktop/shape_files kirkw$ ls
polys_t59_v1.dbf polys_t62_v1.sbn polys_t65_v1.dbf
polys_t59_v1.shp polys_t62_v1.sbx polys_t65_v1.shp
polys_t59_v1.shx polys_t62_v1.shp polys_t65_v1.shx
polys_t59_v2.dbf polys_t62_v1.shx polys_t65_v2.dbf
polys_t59_v2.shp polys_t62_v2.dbf polys_t65_v2.shp
polys_t59_v2.shx polys_t62_v2.shp polys_t65_v2.shx
polys_t59_v3.dbf polys_t62_v2.shx polys_t65_v3.dbf
polys_t59_v3.shp polys_t62_v3.dbf polys_t65_v3.shp
polys_t59_v3.shx polys_t62_v3.shp polys_t65_v3.shx
From my read of the help file each set of shape files would constitute
a layer, and the command should be
v.in.shape dsn=~/Desktop/shape_files ouput=shape_files
However, I get the error that the projection does not match the current
location
GRASS 5.7.cvs:~ > v.in.ogr dsn=Desktop/shape_files/ output=shapefiles
ERROR: Projection of dataset does not appear to match current location.
LOCATION PROJ_INFO is:
datum: nad83
towgs84: 0.000,0.000,0.000
proj: utm
ellps: grs80
a: 6378137.0000000000
es: 0.0066943800
f: 298.2572221010
zone: 15
cellhd.proj = 0 (unreferenced)
You can use the -o flag to v.in.ogr to override this check.
Consider to generate a new location with 'location' parameter
from
input data set.
So I tried importing into a new location thus:
location=new_location
Layer: polys_t59_v1
WARNING: Default driver / database set to:
driver: dbf
database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
*** malloc_zone_calloc[16817]: arguments too large: 3887818265,8
*** malloc_zone_calloc[16817]: arguments too large: 1096034345,4
Bus error
Can someone enlighten me as to what I'm doing wrong here? Thanks
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers at umn.edu
tel: 612.625.2261
fax: 612.625.5212
