[GRASSLIST:2447] Re: 5.7 vector attributes connection
Radim Blazek
blazek at itc.it
Tue Feb 3 05:35:59 EST 2004
On Tuesday 03 February 2004 09:35, francesco.pirotti at unipd.it wrote:
> Hi,
> Now one last question:
> I open my vector files on monitor and when I use d.what.vect and I click on
> one of my polygons, I get all the info BUT it is not editable.
Is it a map in your current mapset? It should be editable.
> Also if I use v.digit I cannot put attributes to my table, it just gives a
> default value which is not editable.
It should be possible, did you get the window with 'Submit' button?
You cannot change the text or you get an error when 'Submit' is pressed?
> I put the v.database settings right, I wonder where the problem is.
Radim
