[GRASSLIST:2464] Re: More info: build error in 5.7 on OSX
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Feb 4 09:02:34 EST 2004
On Wed, 4 Feb 2004, Christopher Fonnesbeck wrote:
> > main.c:112: error: `create' undeclared (first use in this function)
> > main.c:112: error: (Each undeclared identifier is reported only once
> > main.c:112: error: for each function it appears in.)
> > make[2]: *** [OBJ.powerpc-apple-darwin7.2.0/main.o] Error 1
> > make[1]: *** [subdirs] Error 1
> > make: *** [default] Error 1
> Sorry I left this out ... main.c is from g.proj
That would be my fault---I didn't check compiling without OGR/GDAL when I
made some recent changes to g.proj. I have fixed it in CVS or you can move
the #ifdef HAVE_OGR on line 34 to the other side of *create,
Paul
