[GRASSLIST:2525] Re: Was: r.in.gdal and libgdal.1.1.dylib
Markus Neteler
neteler at itc.it
Mon Feb 9 01:12:08 EST 2004
On Sun, Feb 08, 2004 at 10:58:06AM -0700, Christof Bigler wrote:
> The import works. Apparently, the problem was the missing
> libgdal.1.1.dylib in /usr/local/lib. I had a higher libgdal.1.1.9.dylib
> version which had been installed with the GRASS binary distribution for
> OS X. I installed then the libgdal.1.1.dylib from
> http://gdal.velocet.ca/projects/grass.
> Another thing: Is it possible to change the man pages for r.in.gdal? It
> took me literally hours to find out that the input name should be the
> directory and not the file itself. I found this information in a mail
> to the list from, I think, 2001, and also in the Open Source GIS book
> from Neteler & Mitasova.
Christof,
in GDAL-CVS also file names work (bugfix a few days ago).
A trick for your GDAL version:
Try
./filename
instead of
filename
or, as you found out, the directory name.
So for the next GDAL release it will be solved. I suggest
to keep the man page as-is.
Markus
> Thanks
> Christof
> On 06.02.2004, at 12:09, Christof Bigler wrote:
> >Hi
> >I tried to import a raster file (w001001.adf, 358 MB), which is in the
> >directory 'codem1nw'. There must be some problems with the
> >libgdal.1.1.dylib. Here is some output:
> >GRASS 5.0.2 > r.in.gdal in=codem1nw out=codem1nw.r
> >dyld: r.in.gdal Undefined symbols:
> >r.in.gdal undefined reference to _deflateInit_ expected to be defined
> >in /usr/local/lib/libgdal.1.1.dylib
> >Trace/BPT trap
> >GRASS 5.0.2 > gdalinfo --version
> >GDAL 1.1.9.0, released 2003/06/27
> >GRASS 5.0.2 > gdalinfo codem1nw
> >[I received some reasonable output, no error messages.]
> >I work on Mac OS X (10.3.2).
> >Thanks for your help
> >Christof
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
