[GRASSLIST:2538] Xlib - no protocol specified error
francesco pirotti
francesco.pirotti at unipd.it
Tue Feb 10 16:20:31 EST 2004
Hello, strange error this time.
I start grass 5.7 and everything is fine. If I type d.m to start a new
display manager from the terminal it gives me the following error
message:
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
Application initialization failed: this isn't a Tk applicationcouldn't
connect to display ":0.0"
Error in startup script: this isn't a Tk applicationcouldn't connect to
display ":0.0"
while executing
"load /usr/lib/tk8.4/../libtk8.4.so Tk"
("package ifneeded" script)
invoked from within
"package require Tk 8.0"
invoked from within
"package require -exact BWidget 1.2.1"
(file "/usr/local/grass5.7src/dist.i686-pc-linux-gnu/etc/dm/d.m.tcl"
line 2)
If I try to start a new monitor "d.mon start=x1" from the terminal it
gives me a similar error:
ERROR: Graph_Set: can't open Display :0.0
No socket to connect to for monitor <x1>.
Problem selecting x1. Will try once more
All this also happens in grass5.3 (with d.mon and d.dm), and in both
cases ONLY when the command is given from the terminal. If I start a
monitor or the display manager from the tcltk interface in 5.3 it is
fine.
Any ideas? (I am running tk8.4 on Linux Mandrake 10)
Thanks guys,
Francesco Pirotti
CIRGEO - University of Padua
