[GRASSLIST:2557] Re: build errors on r.le
    Markus Neteler
    neteler at itc.it
    Wed Feb 11 05:05:07 EST 2004
On Wed, Feb 11, 2004 at 04:11:36AM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > >>Not a great week for getting the cvs build to work on my linux
> > > >>machine.
> > > >>This time it seems to be with r.le:
> > > >You have to run:
> > > >make mixclean
> > > >make mix
> > > >(better explained in INSTALL file).
> > > This is certainly not the problem. I have successfully updated and
> > > built grass57 from cvs dozens of times, according to the INSTALL file.
> > > Something else is wrong here.
> > This *is* certainly the problem. This is the first time since month
> > that such a "heavy" chance was submitted. You have a file in that directory
> > linked from 5.3, which should be there any more.
> > There is no other way as following these rules:
> > cd /where/your/grass530/lives/
> > cvs update -dP
> > cd /where/your/grass57/lives/
> > make mixclean
> > #here verify, that grass57/raster/r.le/r.le.setup/polytocell/ does
> > # not contain any links to 5.3 (the file bmf_to_cll.c should not be there
> > # any more which is causing the problem on your computer).
> AFAICT, "make copymix" will fall down in this situation; perhaps that
> option should be removed?
> Also, this is one of the reasons why using tricks like:
> 	OBJS = $(subst .c,.o,$(wildcard *.c))
> is generally considered to be a bad idea.
GRASS 5.7 is always open for new developers to improve it.
Markus Neteler
