[GRASSLIST:2565] Re: GRASS 5.3 compilation error and can't start tcltk
    Glynn Clements
    glynn.clements at virgin.net
    Wed Feb 11 13:27:47 EST 2004
alcedo wrote:
> I tried to compile GRASS 5.3 with this command:
>  ./configure --prefix=/usr/local/grass53
> --with-tcltk=yes
> --with-postgres-includes=/usr/local/pgsql/include
> --with-postgres-libs=/usr/local/pgsql/lib
> --with-fftw=yes
> --with-fftw-includes=/usr/local/fftw3/include
> --with-fftw-libs=/usr/local/fftw3/lib
> --with-proj-includes=/usr/local/proj4/include
> --with-proj-libs=/usr/local/proj4/lib --without-motiff
> --with-gdal=/usr/local/gdal/bin/gdal-config
> and after the make command was finished, I got an
> error message like this
> "Compilation error in module: src/paint/p.vrml1.1
> (ignored)".
> I ignored the message and install it. It seems the
> installation was success but when I started the
> tcltkgrass&, there was another error message "bash:
> tcltkgrass: command not found".
> What should I do? It is my first time compiling the
> GRASS 5.3.
You have to start GRASS (with "grass53") before running any GRASS
programs.
Glynn Clements <glynn.clements at virgin.net>
