[GRASSLIST:2575] Re: Xlib - no protocol specified error
francesco pirotti francesco.pirotti at unipd.it
Thu Feb 12 14:07:12 EST 2004
Thanks Glynn,
You are certainly right, about xauth.
I did not yet find a solution:  I found though that if I try to call a
tcltk object directly from a terminal I get the
__________________-
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
____________________--
error BUT if I run the GRASS shell as root I get the diplay manager
without problems ...
I am not an expert on X so I doubt I will be able to solve this
mystery...
If anybody has any ideas, I'll be glad to try them out.
Cheers,
Francesco Pirotti
CIRGEO - University of Padua
On Tue, 2004-02-10 at 15:18, Glynn Clements wrote:
> francesco pirotti wrote:
> > Hello, strange error this time.
> > I start grass 5.7 and everything is fine.  If I type d.m to start a new
> > display manager from the terminal it gives me the following error
> > message:
> This is an X authentication error. This indicates that
> $HOME/.Xauthority (or the file referenced by $XAUTHORITY, if that is
> set) is, in some sense, invalid.
> One common reason for this is if $HOME isn't set correctly. Try
> running "xauth list" to view the list of authentication credentials
> which are available to Xlib.
> Glynn Clements <glynn.clements at virgin.net>
> Incoming mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.571 / Virus Database: 361 - Release Date: 26/01/2004
