[GRASSLIST:2588] Re: Xlib - no protocol specified error
    francesco.pirotti
    francesco.pirotti at unipd.it
    Fri Feb 13 02:08:21 EST 2004
An elegant fix to the problem...
I reinstalled a 9.1 mandrake version instead of the beta 10 version...
Thanks!
Francesco
At 23.17 12/02/2004 +0000, Glynn Clements wrote:
>francesco pirotti wrote:
> > You are certainly right, about xauth.
> > I did not yet find a solution:  I found though that if I try to call a
> > tcltk object directly from a terminal I get the
> > __________________-
> > Xlib: connection to ":0.0" refused by server
> > Xlib: No protocol specified
>In that situation, I would expect you to get the same result for
>running any X program from the terminal.
> > error BUT if I run the GRASS shell as root I get the diplay manager
> > without problems ...
>Check the ownership and permissions on the ~/.Xauthority file; it
>should be owned by you.
>Glynn Clements <glynn.clements at virgin.net>
>Incoming mail is certified Virus Free.
>Checked by AVG anti-virus system (http://www.grisoft.com).
>Version: 6.0.583 / Virus Database: 369 - Release Date: 10/02/2004
Outgoing mail is certified Virus Free.
