[GRASSLIST:2648] Re: NVIZ 5.7 and area vectors
Radim Blazek
blazek at itc.it
Mon Feb 16 13:28:57 EST 2004
On Saturday 14 February 2004 11:13, Miha STAUT wrote:
> NVIZ is not displaying vectors
> Hi,
> My GRASS 5.7 NVIZ is not diplaying area vectors. Is this feature not
> implemented? Where would the possible cause of the trouble be?
It should work, did you try 'tin' from demo data set.
> Is there any other vector format beside dwg or dxf with which one could
> import 3D objects and display them in NVIZ.
dig_ascii, either as regular areas (TIN) or as faces (for vertical planes)
Radim
