[GRASSLIST:2664] Re: error in grass5.7 comiplation
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Feb 17 06:43:52 EST 2004
hamdi ines wrote:
> i'm download the source of grass57src_cvs_snapshot_exp_2004_01_10.tar
> and GRASS-5.3-cvs-head-i18n.22jan2004.tar to install grass57 from the
> source but after execute the make command i get 2 errors:
> [root at localhost grass57_exp_2004_01_10]# CFLAGS="-g -Wall" ./configure
> --with-grass50=/home/grass/
> --with-odbc-includes=/usr/local/include/wine/windows/
> --with-postgres-includes=/usr/local/pgsql/include
> --with-postgres-libs=/usr/local/pgsql/lib
> --with-FFTW-includes=/usr/include/ --with-mysql-libs=/usr/lib/mysql
> --with-blas-libs=/usr/lib --with-LAPACK-libs=/usr/lib
> --with-Freetype-includes=/usr/include
> --with-freetype-libs=/opt/cxoffice/lib/
> --with-NLS-includes=/usr/include/linux --with-Readline-libs=/usr/lib
> --with-DBM-includes=/usr/include/gdbm
> make mix
> make
> the result is:
> make[2]: ***
> [/home/grass57_exp_2004_01_10/dist.i686-pc-linux-gnu/etc/grass_intro]
> Erreur 2
> make[2]: Quitte le répertoire `/home/grass57_exp_2004_01_10/lib/init'
> make[1]: *** [subdirs] Erreur 1
> make[1]: Quitte le répertoire `/home/grass57_exp_2004_01_10/lib'
> make: *** [default] Erreur 1
> please can any one help me to resolv the problem.
Those aren't the errors. The errors will have happened immediately
before that in the make output. You need to provide more detail.
