[GRASSLIST:2668] Re: error in v.distance
Radim Blazek
blazek at itc.it
Tue Feb 17 11:43:17 EST 2004
On Tuesday 17 February 2004 15:18, Leonardo Lami wrote:
> I'm testing v.distance on 5.7 and I choosed the upload table option but at
> the end of the run it says:
> load_table_head(): tab=1,
> /home/Documenti/datigrass/Pisa/prova/dbf//danni.dbf 169 cats selected from
> the table
> SQL: update danni set aac=5435.45 where cat=1
> find_table(): table=danni
> ? aac
> ? danni
> dbmi: protocol error
> SQL: update danni set aac=5664.35 where cat=2
> The error may be in the double "/" in the string:
No, '//' is not problem.
> please can any one help me to solve the problem.
Do you have column 'aac' (floating point) in your table, try db.describe/db.columns.
Try to do the same using db.execute.
echo "update danni set aac=5664.35 where cat=2" \
| db.execute driver=dbf database=/home/Documenti/datigrass/Pisa/prova/dbf/
Radim
