[GRASSLIST:2715] Re: stitching geotiffs
Glynn Clements
glynn.clements at virgin.net
Mon Feb 23 04:35:54 EST 2004
Martin du Saire wrote:
> >>Outstanding! Thank you Richard and Glynn. I think I may eventually
> >>have to r.patch the individual maps. I was playing around with two maps
> >>within a single zone, and the r.stats -a -n map1,map2 output did not
> >>reflect what I expected to be the composite of the two (Actually, the
> >>numbers made no sense at all). One last question:
> >>Without having specific datum in my adjacent zones (14, 16), is there
> >>some way to make upper-bound estimates on the amount of distortion
> >>resulting from the r.proj method=nearest (the maps are land-use/cover)?
> >>Thanks again.
> >>Martin
> >That's a hard question that I will not try to answer directly. Map
> >distortion can involve linear, directional, and/or area distortion. So
> >first you
> Thanks again.
> Having a little trouble with r.proj though:
> ERROR> Input map is outside current region
> I read the thread that involved some problem with southern hemisphere
> projection data from U of Maryland...I am working in the NE USA...geotiffs
> from the USGS site (for what that is worth).
> Region/projection info for the location I am attempting to project the map
> into are:
> g.region -p
> projection: 1 (UTM)
> zone: 19
> datum: nad83
> ellipsoid: grs80
> north: 2734830
> south: 1944930
> west: 1721790
> east: 2041380
That's way off. Valid eastings for UTM are within 350km of the false
500km false easting, i.e. ~166000-834000. That's at the equator; the
valid range decreases with increasing latitude. So, your region is off
by a couple of zones.
Zone 18 is 72-78 degrees West, while zone 19 is 66-72 degrees West.
Also, that particular region appears way South (somewhere to the East
of Guadeloupe); The North value of 2734830 is about right for the
southern tip of Florida (but that would be zone 17).
Glynn Clements <glynn.clements at virgin.net>
