[GRASSLIST:2133] 5.7 and postgres on Mac OSX
David Orme
d.orme at imperial.ac.uk
Mon Jan 5 12:27:58 EST 2004
Hi all,
I'm trying again to build grass 5.7 (from 2004_01_03 snapshots) on mac
10.2.8: make bails out when trying to create libgrass_vect.dylib
because it can't locate -lpq. I've got the postgres libs and includes
in my configure arguments and I can't work out where I'm going wrong.
I've put the steps below - can anyone suggest what's going on?
Thanks,
David
CFLAGS="-g -Wall" ./configure
--with-grass50=//usr/local/src/grass53_exp_2004_01_03
--with-postgres-includes=/usr/local/pgsql/include/
--with-postgres-libs=/usr/local/pgsql/lib/ --with-opengl=no
make mix
make
[clipped]
gcc
-L/usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/
lib -dynamiclib -Wl,-flat_namespace,-U,_cuserid -undefined suppress
lib \
OBJ.powerpc-apple-darwin6.8/area.o
OBJ.powerpc-apple-darwin6.8/array.o OBJ.powerpc-apple-darwin6.8/box.o
OBJ.powerpc-apple-darwin6.8/break_lines.o
OBJ.powerpc-apple-darwin6.8/break_polygons.o
OBJ.powerpc-apple-darwin6.8/bridges.o
OBJ.powerpc-apple-darwin6.8/buffer.o
OBJ.powerpc-apple-darwin6.8/build.o
OBJ.powerpc-apple-darwin6.8/build_nat.o
OBJ.powerpc-apple-darwin6.8/build_ogr.o
OBJ.powerpc-apple-darwin6.8/build_post.o
OBJ.powerpc-apple-darwin6.8/build_shp.o
OBJ.powerpc-apple-darwin6.8/cats.o OBJ.powerpc-apple-darwin6.8/close.o
OBJ.powerpc-apple-darwin6.8/close_nat.o
OBJ.powerpc-apple-darwin6.8/close_ogr.o
OBJ.powerpc-apple-darwin6.8/close_post.o
OBJ.powerpc-apple-darwin6.8/close_shp.o
OBJ.powerpc-apple-darwin6.8/constraint.o
OBJ.powerpc-apple-darwin6.8/dangles.o
OBJ.powerpc-apple-darwin6.8/error.o OBJ.powerpc-apple-darwin6.8/field.o
OBJ.powerpc-apple-darwin6.8/find.o OBJ.powerpc-apple-darwin6.8/graph.o
OBJ.powerpc-apple-darwin6.8/header.o OBJ.powerpc-apple-darwin6.8/hist.o
OBJ.powerpc-apple-darwin6.8/init_head.o
OBJ.powerpc-apple-darwin6.8/intersect.o
OBJ.powerpc-apple-darwin6.8/legal_vname.o
OBJ.powerpc-apple-darwin6.8/level.o
OBJ.powerpc-apple-darwin6.8/level_two.o
OBJ.powerpc-apple-darwin6.8/line.o OBJ.powerpc-apple-darwin6.8/list.o
OBJ.powerpc-apple-darwin6.8/map.o OBJ.powerpc-apple-darwin6.8/net.o
OBJ.powerpc-apple-darwin6.8/open.o
OBJ.powerpc-apple-darwin6.8/open_nat.o
OBJ.powerpc-apple-darwin6.8/open_ogr.o
OBJ.powerpc-apple-darwin6.8/open_post.o
OBJ.powerpc-apple-darwin6.8/open_shp.o
OBJ.powerpc-apple-darwin6.8/overlap.o
OBJ.powerpc-apple-darwin6.8/overlay.o
OBJ.powerpc-apple-darwin6.8/poly.o OBJ.powerpc-apple-darwin6.8/read.o
OBJ.powerpc-apple-darwin6.8/read_nat.o
OBJ.powerpc-apple-darwin6.8/read_ogr.o
OBJ.powerpc-apple-darwin6.8/read_post.o
OBJ.powerpc-apple-darwin6.8/read_shp.o
OBJ.powerpc-apple-darwin6.8/remove_duplicates.o
OBJ.powerpc-apple-darwin6.8/rewind.o
OBJ.powerpc-apple-darwin6.8/rewind_nat.o
OBJ.powerpc-apple-darwin6.8/rewind_ogr.o
OBJ.powerpc-apple-darwin6.8/rewind_post.o
OBJ.powerpc-apple-darwin6.8/rewind_shp.o
OBJ.powerpc-apple-darwin6.8/select.o
OBJ.powerpc-apple-darwin6.8/sindex.o OBJ.powerpc-apple-darwin6.8/snap.o
OBJ.powerpc-apple-darwin6.8/tin.o OBJ.powerpc-apple-darwin6.8/type.o
OBJ.powerpc-apple-darwin6.8/window.o
OBJ.powerpc-apple-darwin6.8/write.o
OBJ.powerpc-apple-darwin6.8/write_nat.o
OBJ.powerpc-apple-darwin6.8/write_post.o -lgrass_gis -lgrass_datetime
-lintl -lgrass_dig2 -lgrass_shape -lgrass_dgl -lgrass_rtree
-lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lpq -o
/usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/lib/
libgrass_vect.dylib
/usr/bin/libtool: can't locate file for: -lpq
/usr/bin/libtool: file: -lpq is not an object file (not allowed in a
library)
make[3]: ***
[/usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/
lib/libgrass_vect.dylib] Error 1
make[2]: *** [subdirs] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
