[GRASSLIST:2139] Re: New modules in GRASS
Glynn Clements
glynn.clements at virgin.net
Tue Jan 6 16:45:41 EST 2004
Uttam Kumar wrote:
> I have a program in "C" related to the fly model
> in GRASS. I want to add that in my GRASS version. How should I use "make and
> gmake" and put it in the raster module, so that I can construct the fly
> model from my raster data. Please suggest how to do it.
Create a subdirectory anywhere within the GRASS source tree (e.g.
src/raster/r.fly) Add your source code to that directory, along with a
Gmakefile (use an existing Gmakefile as a base).
You should then be able to build your module using e.g.:
gmake5 src/raster/r.fly
gmakelinks5
If you want it to be installed immediately (without needing to re-run
"make install"), add the -i switch to both of the above commands,
i.e.:
gmake5 -i src/raster/r.fly
gmakelinks5 -i
To have it built along with everything else when you run "make", add
the directory to the file src/CMD/lists/GRASS (most of the build
process consists of running "gmake5" for each directory which is
listed in that file).
Glynn Clements <glynn.clements at virgin.net>
