[GRASSLIST:2199] Re: How to display satellite data correctly?
    Glynn Clements
    glynn.clements at virgin.net
    Mon Jan 12 16:57:36 EST 2004
Ian Macmillan wrote:
> I am not sure if there is an automated way to do this, perhaps a
> simple script could be written with r.mapcalc. Anybody know how to do
> this?
> The manual way to do this is to use d.histogram to obtain the values
> at each end of the histogram. After that, use r.rescale to change each
> raster. For example,
> d.erase blue
> #need the color to see the curve correctly
> d.histogram map=rast.b1
> r.rescale input=rast output=rast.b1x from=40,140 to=0,255
> #repeat this for the 3 bands, then
> d.rgb red=rast.b3x green=rast.b2x blue=rast.b1x
It would probably be better to just use "r.colors ... color=rules" to
change the intensity mapping; there isn't any need to change the
actual data values.
Glynn Clements <glynn.clements at virgin.net>
