[GRASSLIST:2206] Re: How to display satellite data correctly?
    Kris Nackaerts
    knackaerts at gmx.net
    Tue Jan 13 16:05:57 EST 2004
I had the same problem when trying to visualize hyperspectral images. I
created a script in R (www.r-project.org) to analyze the histogram
output files and create a GRASS script automatically to correctly
rescale the values for visualisation. I could then say like remove the
5% tails.
If you are interested in this script, let me know. Otherwise, I also
used just a PCA transform to get a first impression of what was in the
images.
Regards,
Kris
Hamish wrote:
>> currently I am doing some first steps with GRASS to see how it all
>> works. I've got some sample data (Landsat TM) that I would like to
>> analyze with some of the available functions. However it seems that
>> GRASS is not very good at displaying color images -- at least not if
>> the histograms of the individual channels aren't properly equalized.
>> There is r.colors that should do the trick (I've tried grey.eq) but
>> the results weren't too good. To my opinion the histogram is
>> transformed to be a little like black-and-white but the dynamics
>> aren't well. The display of d.rgb is extremely bright colored but it
>> is difficult to see the real structure -- there are quite a few
>> colored noise pixels that also degrade the quality.
>> Are there better ways to display and visually analyze satellite data?
>> What I am especially missing is a simple linear stretch of the
>> histogram with a 1% cutoff at each end.
> is it really bad data or just each channel using a different color scale?
> see
> http://article.gmane.org/gmane.comp.gis.grass.user/2836
> then use d.rgb, not r.composite.
> A custom color map is a less destructive way if you aren't sure..
> If it is bad data, you can use r.mapcalc or r.null to get rid of it.
> Hamish
