[GRASSLIST:2252] Re: NEXRAD radar stage III precipitation estimates
into GRASS 5.x
Thomas Adams
Thomas.Adams at noaa.gov
Fri Jan 16 07:37:37 EST 2004
Markus et al,
I'm with the Ohio River Forecast Center and we generate Stage-III (now
called MPE - Multi-sensor Precipitation Estimator, due to a number of
algorithmic changes) data for the Ohio River basin and surrounding area.
The problem is, few of the 13 River Forecast Centers (RFCs) save the
data in NetCDF format. The data format used by all RFCs is called 'xmrg'
format (a binary file), which is unique to RFCs. However, there is a C
program (source available) that will decode this data and write it to an
ASCII lat-lon-value file from which you can easily reformat to import
into GRASS, re-sample the data, and display in whatever projection you
desire - I have a script that does this (also available).
Regards,
Tom
Markus Neteler wrote:
>On Thu, Jan 15, 2004 at 12:59:24PM -0700, Tye Parzybok wrote:
>>GRASS users,
>>Is anyone aware of a method to import NEXRAD radar stage III
>>precipitation estimates into GRASS 5.x as a raster or GRASS ASCII
>>raster? It appears as though 'r.stage3' works only with NetCDF data
>>provided by the River Forecast Centers (maybe only the Arkansas Red
>>Basin River Forecast Center), but I'd like to import free radar provided
>>from NCDC at this site:
>>http://has.ncdc.noaa.gov/plclimprod/plsql/HAS.FileAppSelect?datasetname=7000
>>into GRASS 5.x. The data files from this web site are the raw stage III
>>data from NOAA/National Weather Service.
>If it helps: since a few days GDAL supports netcdf, should be general
>netcdf support (fetch the GDAL-CVS version and compile).
>Markus
Thomas E Adams
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040116/0af6f9a5/attachment.html
