[GRASSLIST:2275] Re: vector map over rastr map in one monitor
Glynn Clements
glynn.clements at virgin.net
Mon Jan 19 01:45:45 EST 2004
Eugene Prokopiev wrote:
> Can I draw vector map over rastr map in one monitor such as
> GRASS:~/grass-data > d.mon start=x0 select=x0
> GRASS:~/grass-data > d.rast topo
> GRASS:~/grass-data > d.rast -o water
Most drawing commands (including d.vect and d.vect.area) overlay
whatever is already on the monitor.
> Or how can I combine rast image with vector contours on it?
v.to.rast will convert a vector layer to a raster layer at the current
region's resolution. The resulting raster layer can be overlaid upon
other raster layers using r.patch.
Glynn Clements <glynn.clements at virgin.net>
