[GRASSLIST:2291] Re: output shapefiles - options?
David Orme d.orme at imperial.ac.uk
Tue Jan 20 05:27:46 EST 2004
Hi all,
OK - i didn't experiment enough with data types. I was using:
> alter table tmp add sm_name char(50);
which gave:
> GRASS 5.7.-cvs:~ > v.db.connect -c map=tmp
> WARNING: pg driver: column 'sm_name2', type 0 is not supported
If I use:
> alter table tmp add sm_name varchar(50);
then the pg driver works fine.
Apologies,
David
On 19 Jan 2004, at 17:25, Radim Blazek wrote:
> Which type pricesely? 'char' should be supported.
> Radim
> On Monday 19 January 2004 15:54, David Orme wrote:
>> Hi,
>> I'm working with a series of vector files in Grass 5.7 which I need to
>> export to shapefiles. The geometry is stored as native grass files and
>> the attributes are stored in a PostgreSQL database. I've tried using
>> v.out.ogr but there is a problem with exporting attributes with
>> character data types (all the character attributes are fixed length) :
>>> WARNING: pg driver: column 'sm_name', type 0 is not supported
>> I can think of a number of possible ways forward - getting ODBC
>> working
>> and connecting to the pg table that way, using a PostGIS database to
>> store geometry and using the pgsql2shp dumper program.
>> I've tried working with postgis - one problem is I can't get
>> pg.postgisdb to create a database: I've pointed to all the correct
>> files (incidentally, pg.posgisdb seems to be hard coded to look for
>> libpostgis files in ./lib/contrib - I had to create this folder and
>> link in the libpostgis files in from their installed location in
>> ./lib)
>> but get the following:
>>> /usr/local/grass57/scripts/pg.postgisdb: line 199: createdb: command
>>> not found
>> I _can_ connect to an existing postgis db created within psql and new
>> vector files can be created in that database without problem. The
>> problem is that the geometry table contains linestrings for the areas
>> and also points for the label points and pgsql2shp can't write both
>> types into one file and currently doesn't have the option to
>> selectively export geometry types.
>> Can anyone suggest fixes / tell me if ODBC will export the character
>> columns / suggest another alternative?
>> Many thanks,
>> David Orme
