[GRASSLIST:2294] Re: example plot_raster_map aus progmangrass (p.264)
Daniel Isenegger
disen at geo.unizh.ch
Tue Jan 20 09:57:37 EST 2004
Just for info:
this thing was just an ordering problem:
LIBES= $(DISPLAYLIB) $(RASTERLIB) $(GISLIB): works
instead of
LIBES= $(GISLIB) $(DISPLAYLIB) $(RASTERLIB): does not work
why this is so important, I don't know yet ....
cheers
Hi Glynn,
thanks for you advice. I included it in the Gmakefile:
HOME=$(BIN_CMD)
# include of dirs, e.g.gis.h is in ...
EXTRA_CFLAGS= -I
/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/include
# including of libs: e.g. D_ are in DISPLAYLIB
LIBES= $(GISLIB) $(DATETIMELIB) $(XDRLIB) $(MATHLIB) $(RASTERLIB)
$(DISPLAYLIB) $(IMAGERYLIB) $(VASKLIB) $(VASK)
DEPLIBES= $(DEPIMAGERYLIB) $(DEPGISLIB) $(DEPVASKLIB) $(DEPVASK)
OBJ = ctest.o plotRasterMap.o
ctest: $(OBJ) $(LIBES) $(DEPLIBS)
$(CC) $(LDFLAGS) -o $@ $(OBJ) $(LIBES) $(DEPLIBES)
$(LIST): global.h
$(LIBES): #in case of library change;i.e.they must be here, if in rules
$(DEPLIBS):
and actually a different error:
make -f OBJ.i686-pc-linux-gnu/make.rules
gcc
-L/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/libes/LIB.i686-pc-linux-gnu
-o ctest OBJ.i686-pc-linux-gnu/ctest.o
OBJ.i686-pc-linux-gnu/plotRasterMap.o -lgis -ldatetime -lz -lm
-lraster -ldisplay -lI -lvask
/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/libes/LIB.i686-pc-linux-gnu/libI.a
/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/libes/LIB.i686-pc-linux-gnu/libgis.a
/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/libes/LIB.i686-pc-linux-gnu/libvask.a
/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/libes/LIB.i686-pc-linux-gnu/libdisplay.a(raster.o)(.text+0x1a9):
In function `draw_cell':
/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/libes/display/raster.c:171:
undefined reference to `R_move_abs'/
i have to check that: if I get any further from here
thanks dani
Daniel Isenegger wrote:
>> I tried to implement the example plot_raster_map aus progmangrass
>> (p.264) to get used to the C-programming in GRASS.
>> I use a source code installation of grass 5.0.3 on a linux Suse 8.2
>> After several iteration of the Gmakefile and the plot_raster_map I
>> allways get a hell of an error stack which starts with:
>> /data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/libes/LIB.i686-pc-linux-gnu/libgis.a(color_range.o)(.text+0xc2):
>> In function `G_get_color_range':
>> /data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/libes/gis/color_range.c:46:
>> undefined reference to `floor'/
>> # einbinden der libs: e.g. D_ are in DISPLAYLIB
>> LIBES= $(GISLIB) $(RASTERLIB) $(DISPLAYLIB) $(IMAGERYLIB) $(VASKLIB) $(VASK)
You need to add $(MATHLIB) to this line.
To be on the safe side, use of $(GISLIB) should always be followed by:
as various parts of it may depend upon one or more of those libraries.
-- Glynn Clements <glynn.clements at virgin.net>
Daniel Isenegger schrieb:
> Hi there,
> ./bin/gmake5
> SRC =
> CMD =
> /data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/CMD
> UNUSED =
> /data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/unused
> HEADER = head.i686-pc-linux-gnu
> ARCH = i686-pc-linux-gnu
> GISBASE =
> /home/gis/disen/links/ipodlas0.1/grass/grass5sources/grass-5.0.3/dist.i686-pc-linux-gnu
> VERSION = 5.0.3 October 2003
> gcc
> -I/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3/src/include
> -g -O2 -I
> -c plotRasterMap.c -o OBJ.i686-pc-linux-gnu/plotRasterMap.o
> gcc
> OBJ.i686-pc-linux-gnu/plotRasterMap.o -lgis -lraster -ldisplay -lI
> -lvask -lz
> the test code looks like this:
> /* Versuch: rastermap von Grass aus zu zeichnen */
> #include "gis.h" // Grass-lib einbinden
> plot_raster_map(char *name,char *mapset,int overlay) {
> struct Colors colors;
> CELL *raster;
> int row, fd, top, bottom, left, right;
> /* perform plotting setup */
> D_setup(!overlay);
> D_get_screen_window(&top, &bottom, &left, &right);
> if (D_cell_draw_setup(&top, &bottom, &left, &right)) //ERROR
> raster = G_allocate_cell_buf( );
> /* open raster map, read and set the colors */
> // neu eingefuegt
> int init = G_init_colors(&colors);
> int color_table = G_read_colors(name, mapset,&colors);
> if((fd = G_open_cell_old (name, mapset)) < 0) // ERROR
> if(G_read_colors (name, mapset, &colors) < 0) //ERROR
> D_set_colors(&colors);
> /* plot */
> D_set_overlay_mode(overlay);
> for(row=0; row >= 0; ) {
> if (G_get_map_row(fd, raster, row) < 0) //ERROR
> row = D_draw_cell(row, raster, &colors);
> G_close_cell(fd);
> G_free_colors(&colors);
> G_free(raster);
> the Gmakefile like this:
> HOME=$(BIN_CMD)
> # include der dirs, zb hier ist gis.h
> EXTRA_CFLAGS= -I
> $(VASK)
> $(CC) $(LDFLAGS) -o $@ $(OBJ) $(LIBES) $(XDRLIB)
> $(LIST): global.h
> $(GISLIB): #in case of library changes
> $(RASTERLIB):
> $(DISPLAYLIB): #muss auch hier aufgefuehrt sein, wenn unter LIBES
> aufgefuehrt
> $(LIBES):
> $(DEPLIBS):
> did forget to include a module?
> can anybody tell me how to go on?
> Thanxs for any advice Dani isenegger
> ps the status after the installation was;
> GRASS is now configured for i686-pc-linux-gnu
> Source directory:
> Build directory:
> Installation directory:
> C compiler: gcc -g -O2
> FORTRAN compiler: g77
> NVIZ: yes
> X11 support: yes
> DBM support: no
> JPEG support: yes
> TIFF support: yes
> PNG support: yes
> GD support: no
> Tcl/Tk support: yes
> PostgreSQL support: yes
> OpenGL(R) support: yes
> ODBC support: yes
> FFTW support: no
> BLAS support: no
> LAPACK support: no
> Motif support: no
> FreeType support: no
> GLw support: no
> NLS support: no
> Readline support: no
