[GRASSLIST:2302] Re: Grass 5.7 database
Markus Neteler
neteler at itc.it
Wed Jan 21 06:07:27 EST 2004
On Mon, Jan 19, 2004 at 06:27:29PM +0100, Radim Blazek wrote:
> On Monday 19 January 2004 08:57, francesco.pirotti wrote:
> > Hi all,
> > I have a question on Database management with GRASS 5.7...
> > In the part of the tutorial "Geometry Stored in PostGRASS database table
> > using PostGIS"
> > (http://grass.itc.it/grass51/tutorial/geom_storage.html#PostGRASS)
> > The example says to take a shape file registered with v.shape.register and
> > use v.convert to import it into a PostGRES database with PostGIS format. It
> > did not work with me (gives me a "vector map not found" error), and the man
> > page for v.convert says that it is used to convert 5.0 vectors to 5.1... Am
> > I doing something wrong or am I missing something?
> v.convert converts 5.0 vectors to 5.7 format. If you want to store vectors in
> PostGIS, run v.in.ogr.
I have fixed the tutorial. Thanks for notification.
Markus
