[GRASSLIST:2346] RE: vector map over rastr map in one monitor
Uttam Kumar uttamkumar123 at hotmail.com
Fri Jan 23 08:32:00 EST 2004
    You can try out the following:
1. d.mon start=x0 select=x0
2. d.rast map=topo
3. d.vect map=water
It will display a raster image (topo) and overlay the vector layer (water)
over it.
Good Luck.
uttam.
>From: Eugene Prokopiev <john at rmts.donpac.ru>
>To: grasslist at baylor.edu
>Subject: [GRASSLIST:2264] vector map over rastr map in one monitor
>Date: Sun, 18 Jan 2004 15:57:35 +0300
>Hi,
>Can I draw vector map over rastr map in one monitor such as
>GRASS:~/grass-data > d.mon start=x0 select=x0
>GRASS:~/grass-data > d.rast topo
>GRASS:~/grass-data > d.rast -o water
>Or how can I combine rast image with vector contours on it?
>Thanks,
>Eugene Prokopiev
_________________________________________________________________
NRI’s, Free Money transfer to India.
http://server1.msn.co.in/msnleads/citibankrca/citibankrca2.asp?type=hottag
Click here.
