[GRASSLIST:2352] Re: GIS ERROR: error while writing to temp file: No such file or directory
    Edmund Blackadder
    edmund at helmug.gr
    Sat Jan 24 07:05:56 EST 2004
Well, I found a workaround so i managed to finish my work. I do not
know what the problem was though.
I rectified each band alone. It worked perfectly.
I do not know the reason of the problem, but maybe the workaround
should be considered as one more option when encountering problems with
i.ortho.photo..
Thanks for help me Glynn :-)
  i still think it has something to do with the direct copy of the data
from Windows..
Konstantinos Theofilis
On 24 Jan 2004, at 03:43, Glynn Clements wrote:
> edmund at helmug.gr wrote:
>> My umask value is 0022.
>> Now i have tried the following:
>> Compiled and installed a new version of GRASS 5.3 in another
>> directory. THe problem insists. "GIS ERROR: error while writing to
>> temp file:no such file or directory"
>> I wonder if the data has anything to do. The data come from a
>> XP/cygwin installation of GRASS 5.0.2. I just copied the folders and
>> chown-chmod them.
> So now all files and directories are owned by you, and are
> readable/writeable by you, right?
>> Any new ideas???Deadlines are running out...:-(
> Are there any upper/lower case mismatches? Windows doesn't care about
> case, but Unix does. If GRASS tries to read a file called "GROUP", and
> the file is actually called "group", it will work on Windows but not
> on Unix. I'm not sure about OSX, though.
> If the Windows installation is still operational, you could try
> exporting the data (using r.out.* etc) from the Windows installation
> then importing it (using r.in.* etc) into a newly-created location on
> the Mac.
> In any case, direct copying of database directories between different
> architectures isn't reliable. This is particularly relevant if the
> systems have differing byte order or word size.
> Glynn Clements <glynn.clements at virgin.net>
