[GRASSLIST:2374] Re: v.proj help
Christian G. Tveen cgt at navicon.dk
Wed Jan 28 05:57:58 EST 2004
Thanks a lot!!!
I had't really realized that units had to be meters (I'm very much used
to only use lat/lng even in projected maps.)
I have two further questions: From where did you obtain the precise
values for the boundaries ? (I saw my rounded values written by v.proj)
A more general question is how to obtain the initial WIND/DEFAULT_WIND
file. When starting out, I only have the LL boundaries. Do I manually
calculate the Mercator boundaries for those files, or is there a clever
way ? (g.region initially requires a DEFAULT_WIND file, so somehow I
need a boot-strap)
Best regards
Christian
Glynn Clements wrote:
>Christian G. Tveen wrote:
>>Then I've tried to project the data to mercator projection, into a new
>>handmade location. Here I cant display the projected data ! The
>>projection was done by inserting the following PROJ_INFO into the new
>>location/PERMANENT:
>>proj: merc
>>ellps: clark66
>>lat_0: 57.0
>>lon_0:11.0
>>zone: -1
>lat_0 isn't a valid parameter for that projection.
>>To get the WIND and DEFAULT_WIND files, I did a g.region on the imported
>>file and changed the projection to 99
>>The WIND file looks like:
>>proj: 99
>>zone:0
>>north: 57:54:28N
>>south: 54:24:11N
>>east:    15:33:24E
>>west: 7:38:57E
>>cols: 99
>>rows: 44
>>e-w resol: 0:04:47.54
>>n-s resol: 0:04:46.75
>This isn't valid. The region boundaries and resolution have to be
>specified in the map's coordinate system (i.e. feet/metres, not
>degrees).
>>I think the
>>THen v.proj -s input=ponet location=global mapset=dk
>>The output is somewhat big numbers:
>>north: 7911408
>>south: 7211788
>>east 502391
>>west 364972
>If I project your lat/lon region into the location:
>	proj: merc
>	ellps: clark66
>	lat_ts: 0.0000000000
>	lon_0: 11.0000000000
>	k_0: 1.0000000000
>I end up with:
>	north:      7904761.9047619
>	south:      7206349.20634921
>	west:       -369444.44444444
>	east:       504166.66666667
>Which isn't that far off, except for the Western boundary. Maybe
>something doesn't like the negative coordinate; most map projections
>choose their parameters so that coordinates are always positive (e.g.
>by adding a false Easting or Northing).
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040128/6c2b6160/smime.bin
