[GRASSLIST:2385] Re: scan-resolution for maps
Wolfgang von Hansen
wvhansen at web.de
Thu Jan 29 02:31:53 EST 2004
"E. Koster" <niwlered at hotmail.com> schrieb am 28.01.04 18:01:40:
> I remember from several years ago (grass4.x) there was a document from Cerl
> talking about resolution and accuracy of maps. [...] Could you please
> send me a reference, or introduce me to any other literature on this
> subject?
I don't know that document but it is not too difficult to calculate scan resolution based on some simple assumptions. The only difficulty involved is that most scanners need the resolution in dpi whereas real world units are usually metric.
> the map I want to scan was created in 1639 using a copper-plate. The
> instrument used to engrave can make lines up to a 0.1 mm in width. The
> resolution of the map is 1:2.400.
Actually, 1:2400 is *not* a resolution but a scale. BTW, it is not easy to define resolutions for analog products because these have something like an infinite resolution (but still only a limited accuracy).
> At what resolution I should scan not to
> have an overkill of information?
You gave two different types of information, so one can define two different formulae to compute a scan resolution. The easier and better one is the line width:
There exists a well know sampling theorem (by Shannon) which states that in order not to loose any vital information, one has to sample with twice the maximum frequency of the data. In your case these are pixels of 0,05 mm size. With 1 in = 25,4 mm the result is 25,4 / 0,05 dpi = 508 dpi.
The other information is the scale of the map that relates the size of real world objects to the size of their cartographical representation. In order to find a scan resolution one has to define the real world area corresponding to one pixel of the result. Let us assume that a pixel size of 50 cm is sufficient to display everything but also necessary for the geometrical precision. This means that one pixel is 50 cm / 2400 = 0,21 mm. According to the above formula this results in 122 dpi.
Now you have got a range of possible scanner settings where you can choose values from. Of course, you'll have to see whether the 50 cm of the second formula make sense for your application. In any case, more than 508 dpi is not necessary to reproduce the map.
HTH,
Wolfgang
______________________________________________________________________________
Erdbeben im Iran: Zehntausende Kinder brauchen Hilfe. UNICEF hilft den
Kindern - helfen Sie mit! https://www.unicef.de/spe/spe_03.php
