Daniel Isenegger wrote: > I try to get started with Grass programming with the code example on > p.264 from the progmangrass50. Can you provide a section number? Page numbers aren't much help; they change whenever something is added or removed. -- Glynn Clements <glynn.clements at virgin.net>
