[GRASSLIST:2413] Re: v.proj problems
morten at untamo.net
Fri Jan 30 16:13:02 EST 2004
Please do what Paul is asking for: send the output of g.region -p and
g.projinfo for both your lonlat and utm location. Then maybe we can help
you.
On Fri, 30 Jan 2004, Ian Macmillan wrote:
> Quoting Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> > On Thu, 29 Jan 2004, Ian Macmillan wrote:
> > > Hi all, I am trying to convert some data from a lat-long projection to a
> > utm
> > > projection. I am using v.proj, but the projected vectors come out in the
> > wrong
> > > location (northern hemisphere, when they should be southern). The area I
> > am
> > > using is in Chile, so it is in the southern hemisphere, I was thinking
> > this
> > > might be the problem? The v.info results are listed here.
> > > Projection: UTM (zone 19)
> > > |N: 8062436 S: 3775859
> > > |E: 774210 W: -213663
> > > Projection: Latitude-Longitude (zone 0)
> > > |N: -18 S: -56
> > > |E: -66 W: -76
> > > Both projections use the wgs84 datum.
> > What are the PROJ_INFO files for your locations? (g.projinfo)
> > And the output of g.region -p ?
> > I'm thinking it should say zone -19, not 19, although that wouldn't affect
> > v.proj which should get all the projection information from PROJ_INFO. If
> > it has zone: 19 then it should also contain south: defined although
> > zone: -19 on its own should also work.
> Hey all, so I am a bit of an idiot, the vector I am trying to import extends
> much farther than zone 19. I figured this must be the main problem. However,
> when I converted the vector to a raster (v.to.rast) and cut the raster down to
> an area that is definitely within zone 19 (using r.mapcalc, and resizing the
> region), using r.proj (in the utm location) only yields an error message saying
> the proposed raster lies outside of my current region (even though the region
> was set to fit an area larger than the raster.
> Ack, i am lost, i have used r.proj successfully many times, but something seems
> to be wrong here.
> My proj_info file says zone: 19 and south: defined in the utm location.
> Any ideas?
> Thanks a bunch, ian
