[GRASSLIST:3812] Re: overlay
leo.lami at katamail.com leo.lami at katamail.com
Tue Jul 6 09:50:59 EDT 2004
 I have a problem with th v.overlay command.
 I have two vectors (imported by OGR from shapes) that have several
 boundary completely overlapped because one derive from the other.
 If I use v.overlay with "and" option I have a vector that is not the
 correct intersection of them.
 How you can see from the png file linked, same polygons of the first
 vector (with one boundary overlapped with the boundary of the other vector)
 are not included in the intersection vector (bottom of the picture).
 In the oter case you can see that, in the same situation, I have the
 polygons included in the intersection vector (top of the picture).
 The first vector has black line and no filled area, the second has red
 line and not filled area and the intersection vector has green line and
 yellow filled area.
  Someone had the some problem or does someone know the cause?
  Thank you
  Leonardo Lami
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040706/9f2d77dc/example.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040706/9f2d77dc/example-0001.png
