[GRASSLIST:3855] Re: Import Arc/Info e00 data into 5.7
Markus Neteler neteler at itc.it
Fri Jul 9 03:39:05 EDT 2004
On Fri, Jul 09, 2004 at 01:09:20PM +1200, Hamish wrote:
> > I've been wandering around the net for a while now, but haven't found
> > a good way to import DCW data into GRASS 5.7...
> > If you have a good solution to this problem, please let me know. Or if
> > there is no easy way, let me know, too, so I can start working on the
> > hard one...
> Alphabet soup:
> AFAIK...
> DCW is now known as VMAP.
> VMAP can be read with OGR's OGDI import filter.
> So v.in.ogr is the GRASS 5.7 module to use, but you might have to use
> ogr2ogr first? Also try the ogrinfo program.
No, when having compiled OGR with OGDI support, then GRASS 5.7 should
read VMAP0 directly.
Markus
