[GRASSLIST:3865] Re: Import Arc/Info e00 data into 5.7
tatel at euskalnet.net
Fri Jul 9 19:29:22 EDT 2004
Hi all,
I would to know the command to import vmap0 directly with v.in.ogr?
Roman
(who tried to made it and finally worked with ogr2ogr first)
----- Jatorrizko Mezua -----
Norengandik: Markus Neteler <neteler at itc.it>
Data: Ostirala, Uztaila 9, 2004 9:39 am
Gaia: [GRASSLIST:3855] Re: Import Arc/Info e00 data into 5.7
> > So v.in.ogr is the GRASS 5.7 module to use, but you might have to
> use> ogr2ogr first? Also try the ogrinfo program.
> No, when having compiled OGR with OGDI support, then GRASS 5.7 should
> read VMAP0 directly.
> Markus
