[GRASSLIST:3895] Re: interrupted map projection in batch
Hamish
hamish_nospam at yahoo.com
Tue Jul 13 20:06:05 EDT 2004
> I want to process raster data in latitude and longitude for the
> western hemisphere with an interrupted map projection. The first step
> is to clip the whole hemisphere raster layer into the north and south
> parts. Then project each part with the same projection but different
> central meridians. Then mosaic back together using the appropriate x
> offset to get them to line up. The result should look like the 8 KB
> jpg attached. I want to do this with a batch script because I have
> many maps.
> (See attached file: whemi.jpg)
Just looking at that nice jpeg image, you may be interested in the
'viewproj' capabilities:
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass/src.contrib/LM/viewproj/html/viewproj.examples.html
http://article.gmane.org/gmane.comp.gis.grass.devel/2273
Caveat:
http://article.gmane.org/gmane.comp.gis.grass.devel/3890
Hamish
