[GRASSLIST:3905] Re: gmath compiling error in grass 5.3 and 5.7
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Jul 14 05:34:50 EDT 2004
On Wed, 14 Jul 2004, Markus Neteler wrote:
>>> I have made a try to remove $(GMATHLIB) from the ps.map Makefile in
>>> GRASS 5.7. Seems to work. So I have removed it in CVS as well.
>> ps.map requires $(IMAGERYLIB), which requires G_alloc_matrix() from
>> $(GMATHLIB), but doesn't list $(GMATHLIB) as a dependency.
>> Consequently, this change causes a build failure for ps.map.
> Ok, re-added.
>> lib/imagery/Makefile should probably have EXTRA_LIBS=$(GMATHLIB) (and,
>> AFAICT, $(VASKLIB) as well).
> Isn't this already there?
Yes I fixed it yesterday. So there is a good chance ps.map might compile
OK with out the $(GMATHLIB) now. But I'm not sure.
