[GRASSLIST:3909] Compiling 5.7 with hard links (Was: concurrent use)
tatel at euskalnet.net tatel at euskalnet.net
Wed Jul 14 13:36:22 EDT 2004
Hi Glynn, Marcus
As you say, after updating again from cvs I compiled 5.7 succesfully with:
make mixclean
make mix
make distclean
./configure
make
Thank you very much for your help.
Best regards,
Roman
O----- Jatorrizko Mezua -----
Norengandik: Markus Neteler <neteler at itc.it>
Data: Azteazkena, Uztaila 14, 2004 9:25 am
Gaia: [GRASSLIST:3901] Re: concurrent use
> On Wed, Jul 14, 2004 at 12:41:35AM +0100, Glynn Clements wrote:
> > tatel at euskalnet.net wrote:
> > > After recompiling from CVS, this is what I get when starting 57:
> > > /usr/local/grass-5.7.cvs/etc/Init.sh: g.gisenv: command not found
> IMPORTANT (concerns all users compiling a fresh GRASS 5.7 from CVS):
> Due to the change from hard links to soft links, a recompilation
> requires a cleaned binary tree.
> I had the same problem and solved it my running
> make distclean
> configure ...
> make
> The change from hard to soft links is somewhat not discovered
> by the Makefile system. So simply run 'make distclean',
> then recompile and the problem should be gone.
> Subsequent recompilations should *not* need 'make distclean'
> every time. It's just required to migrate from hard to soft
> links.
> Markus Neteler
