[GRASSLIST:3934] Re: merging vector attributes from an external .dbf file
    Radim Blazek
    blazek at itc.it
    Fri Jul 16 03:59:18 EDT 2004
You have to reclass the vector with values from "label" column
and then relink to the new dbf table (v.db.connect).
Unfortunately v.reclass col=label will not work because it is not
of type integer, so you have to generate a reclass file
(db.select | awk ....) or open the dbf file in openoffice
and change the type to integer.
Radim
On Thursday 15 July 2004 19:44, Jed O. Kaplan wrote:
> Hello Grass users,
> I am struggling to import a .e00 vector map into GRASS and retain
> attributes contained in a separate .dbf file that serves as a lookup
> table.  Here are the details.
> I started with an Arc .e00 export file that contains one vector
> coverage.  In addition I received a separate, complementary .dbf file
> that contains several descriptive fields related to the polygons in the
> .e00 file.
> Here's what I've done so far:
> 1. Import the .e00 file into GRASS 5.3 (using m.in.e00).
> 2. Switch to GRASS 5.7
> 3. Convert the v5.3 vector to a v5.7 vector
> I now have both a GRASS vector file and a .dbf file (that was
> automatically generated during the import).  This .dbf file contains
> two columns: "cat" and "label".
> I have a second .dbf file (the one that came with the dataset).  This
> .dbf file has several columns, including a "label" field that matches
> up with the "label", but this file has no "cat" column (i.e. it is a
> lookup table based on the field "label").
> Now is where I get stuck. How can I link all of the information that is
> in this second, external table with the table that was generated by
> m.in.e00?
> I hope I have been clear enough.  I am fairly new to GRASS and any
> advice you may have would be much appreciated.
> Thank you,
> Jed Kaplan
