[GRASSLIST:3969] SV: Yet another configure question re odbc
Lars Forseth lars.forseth at ntfk.no
Tue Jul 20 02:49:12 EDT 2004
Hi!
I'm also running SuSE 8.2. And the same problem came up when I compiled GRASS 5.0.3. The thing is, there are two ODBC libraries for Linux/UNIX. One is iODBC, the other is unixODBC. They are, so says yast anyway, mutualy incompatible. So both cannot be installed at the same time. But you could try to have them both installed. Anyhow I removed the one I had installed (sorry don't remember which that was, I'm at work writing this on outlook and win2000). Use yast to check what you have installed, and remove this, and install the other.
mvh/regards
larsf
-----Opprinnelig melding-----
Fra: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]På
vegne av C.S. Cornuelle
Sendt: 19. juli 2004 18:57
Til: grasslist at baylor.edu
Kopi: C.S. Cornuelle
Emne: [GRASSLIST:3961] Yet another configure question re odbc
Hi.  Hamish, this one is probably for you, judging by over older
emails.  Sorry.  :^)
After years of waiting, I'm installing grass 5.7 on my SuSe 8.2
machine (linux).  Having installed the postgresql package running
the configure script for grass gives this:
	checking whether to use ODBC... yes
	checking for location of ODBC includes...
	checking for sql.h... yes
	checking for location of ODBC library...
	checking for SQLConnect in -lodbc... no
	configure: error: *** Unable to locate ODBC library.
Doing find produces:
	/usr/lib/psqlodbc.la
	/usr/lib/psqlodbc.so
However this lib should of course be searched automatically, and
explicitly including it on the command line for configure does not
help.  And of course one email claimed that in order to get postgresql
and grass to communicate one does not need an odbc.  I would like them
to talk, so any advice you could give would be appreciated.
This means that --with-odbc-libs=no is not an option for me, right?
Thanks.
Adios,
Chris Cornuelle
bob at xmission dot com
