[GRASSLIST:3970] Re: Yet another configure question re odbc
Markus Neteler
neteler at itc.it
Tue Jul 20 03:34:11 EDT 2004
On Mon, Jul 19, 2004 at 10:56:54AM -0600, C.S. Cornuelle wrote:
> Hi. Hamish, this one is probably for you, judging by over older
> emails. Sorry. :^)
> After years of waiting, I'm installing grass 5.7 on my SuSe 8.2
> machine (linux). Having installed the postgresql package running
> the configure script for grass gives this:
> checking whether to use ODBC... yes
> checking for location of ODBC includes...
> checking for sql.h... yes
> checking for location of ODBC library...
> checking for SQLConnect in -lodbc... no
> configure: error: *** Unable to locate ODBC library.
If you don't need ODBC, you can simply disable it.
Probably we should change
ODBC library... -> unixODBC library...
> Doing find produces:
> /usr/lib/psqlodbc.la
> /usr/lib/psqlodbc.so
This is not the right library.
You need unixODBC (see REQUIREMENTS.html file) in the source code
package.
> This means that --with-odbc-libs=no is not an option for me, right?
No, it should be simply:
--without-odbc
Regards
Markus
