[GRASSLIST:3986] Re: Grass 5.7 vectors
Hamish
hamish_nospam at yahoo.com
Wed Jul 21 20:37:17 EDT 2004
> I've started using 5.7 and now when I use d.vect I get a series of
> crosses at each point, instead of a series of lines connecting the
> points.
> I'm aware the sites and vectors have been merged in 5.7 so I suspect
> I've imported my vectors as sites instead of vectors,
Sounds right. Try using 'd.vect icon=basic/circle type=point' and
'd.vect type=line' to be sure. I prefer circles to the crosses for point
data, but maybe they are too slow to draw to be the default. As is they
don't distinguish themselves from area centroids.
d.what.vect is handy as well.
> but I can't find anything in the man pages that explains how to import
> as vectors instead (or convert a series of sites to vectors).
> I've tried using the -t switch on v.in.ascii, but I still get sites.
from the (cvs) help page:
DESCRIPTION
v.in.ascii converts a vector map in ASCII format to a vector map in
binary format. The module may be run in 2 modes:
* standard: if 'input' option is used the module reads GRASS ASCII
vector from the dig_ascii directory
* points: if 'input' is not used the module reads points from
standard input. Each point must be defined on one row, values separated
by a user definable deliminator. If the 'columns' option is not defined,
default names are used. It is possible to specify the column order for
the x,y,z coordinates and category values.
... So it sounds like you are feeding it input from stdin and getting
point data out, as designed. Short of someone adding a new flag for
treating the stream of coordinates as a line, you'll need to create a
GRASS vector-ascii file as detailed in the help page (using "L"
features).
See GRASS 5.3's v.in.garmin.sh for an example of how to create one of
these automatically from a shell script.
Hamish
