[GRASSLIST:4009] Re: Landsat image mosaicing
Ian MacMillan ian_macmillan at umail.ucsb.edu
Fri Jul 23 12:37:04 EDT 2004
You first need to get rid of that black space around the edge by
running r.null on both tiles.  If you are worried about losing
information in the image (all zeros) then you could run r.null again
after you have r.patch'ed the tiles together (and set your region), and
set all your nulls back to zero.
Your colors are always going to be different on each tile (each tile
was taken at different times, with different lighting, different
terrain, etc.) but it should be fine.
Good luck,
Ian
On Jul 23, 2004, at 12:07 AM, Firman Hadi wrote:
> Dear all,
> I've been trying to mosaic two scenes of Landsat images (2 rows) by
> using i.image.mosaic.tcl in GRASS 5.3.0 and r.pacth. I want the mosaic
> image will be smooth, but the result is far from good.
> I hope any of you could help me to solve this problem.
> Thanks for your help.
> Regards,
> Firman Hadi,
> Research Group on
> Monitoring Environmental Dynamics (ReGMED),
> Department of Geodetic Engineering and Geomatics,
> Institute Technology of Bandung,
> Jl. Ganesha 10, Bandung
> INDONESIA
> <mosaic.png>
