[GRASSLIST:4038] Re: GRASS 5.7: i18N multilingual support implemented
Paolo Cavallini
cavallini at faunalia.it
Tue Jul 27 11:20:32 EDT 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
OK, so I can start with the translation.
May I ask you some help in case I get stuck?
All the best.
pc
At 17:05, venerdì 09 luglio 2004, Markus Neteler has probably written:
> Buongiorno, Salut, Hi, Guten Tag, Moin,
> Haló, ??, ???????????, ...
> To enable multilingual support in GRASS 5.7 I have
> implemented i18N support. Now we need translators...
> The POT/PO/MO gettext files method is used as in GRASS 5.0.
> What's already available for translation:
> - parts of lib/gis/ are prepared
> - r.colors' rules.c file (in 5.3) which is linked into 5.7
> to illustrate how it works in a module.
> Now:
> - read grass57/locale/README for details (it's fairly simple)
> - existing messages may be translated with kbabel or equivalent
> program
> - generally all C files containing messages must be edited
> to add the _(...) macro and glocale.h include (explained
> in the file grass57/locale/README )
> - all formattings and variables must be kept
> - GRASS 5.7 must be configured with '--with-nls' and recompiled.
> Now we need translators - needed skills:
> - usage of kbabel program (easy)
> - optionally knowledge how to modify C files to implement the
> required message string _(...) macros (medium)
> and ability to send diffs against CVS of the modified
> files.
> Note that kbabel is able to import existing .po file
> (files containing translated strings) to semi-automate the
> translation. You may borrow then from other projects (check
> their license first).
> Even partial translation is possible as messages will be merged
> into existing .po files for the various languages. Of course some
> coordination is needed for each language.
> The 5.7-CVS comes now with a few German messages to illustrate
> how it works. It should be possible to use the existing
> Russian 5.0 translations and the new Japanese translations.
> Cheers
> Markus Neteler
Paolo Cavallini
cavallini at faunalia.it www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
GPG key @: www.faunalia.it/Public_key_Paolo.asc
Only free software: www.gnu.org / www.linux.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBBnLA/NedwLUzIr4RAhEeAJ9AN7aCK4jzX4XKXnC2gdJIaDUapACgm0Vr
mthsQGwPIj6qv0RqtG9Bl6c=
=CN62
-----END PGP SIGNATURE-----
