[GRASSLIST:3621] Re: function to compare rasters visually
Stephan Holl
sholl at gmx.net
Tue Jun 8 02:56:58 EDT 2004
Hello Benjamin,
On Mon, 7 Jun 2004 19:22:25 +0200 Benjamin Ducke
<benducke at compuserve.de> wrote:
> Dissolve seems to be what graphics programs like
> Photoshop call "transparency" and is usually
> implemented using an alpha blending.
> It should not be too hard to implement something
> like this in a GRASS rast module.
> The Open Source program Gimp (www.gimp.org) should have all
> the necessary algorithms.
> Also, Graphics Gems (Vol. I) has an alpha blending algorithm.
> I would like to see something like this in a GRASS module,
> but I really think alpha blending should be done by adding the
> needed functionality to d.rast. Maybe one could add an integer
> 1..100 to the '-o' parameter to specifiy the strength of
> transparency?
Probably QGIS is a solution for your questions. It supports
alpha-blending and GRASS-rasters and -vectors as well when compiling
with the GRASS-plugin.
Have a look at
http://sourceforge.net/projects/qgis
A detailed instruction how to set this up is here:
http://community.qgis.org
hth
Stephan Holl
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040608/78980ca8/attachment.bin
