[GRASSLIST:3624] Re: v.surf.idw
Radim Blazek
blazek at itc.it
Tue Jun 8 09:39:16 EDT 2004
How did you make your vector temp20000130180000?
I guess that you have run something like
cat temp20000130180000 | v.in.ascii catcol=4
In that case a category assigned to ALL points is '4'
and all points are linked to 4. row (data = -2).
Try to query the vector by d.what.vect.
Radim
On Monday 07 June 2004 14:12, Sabine Grabner wrote:
> hello,
> i try to interpolate my meteorological data with the following vector data:
> rsdb=> select * from temp20000130180000;
> x | y | z | parameter | data | refper | name
>- 10.7814 | 46.7581 | 2070 | 4 | -7 | 0 | Kurzras
> 11.1667 | 46.6734 | 392 | 4 | 34 | 0 | Meran
> 10.5 | 46.9 | 1360 | 4 | 25 | 0 | Nauders
> 11.023 | 46.8672 | 1938 | 4 | -2 | 0 | Obergurgl
> 10.875 | 46.9242 | 2850 | 4 | -44 | 0 | Pitztaler Gletscher
> 10.8794 | 46.9269 | 2850 | 4 | -46 | 0 | Pitztaler Gletscher
> 10.913 | 46.8594 | 1906 | 4 | -1 | 0 | Vent
> (7 rows)
> rsdb=> \d temp20000130180000
> Table "public.temp20000130180000"
> Column | Type | Modifiers
> x | double precision |
> y | double precision |
> z | integer |
> parameter | integer |
> data | double precision |
> refper | integer |
> name | character varying(20) |
> rsdb=>
> first question:
> can anyone tell me how to set a mask as mentioned in the v.surf.idw as the
> command r.mask is neither documented nor does it work on my grass57
> second question:
> interpolationg with r.surf.idw all cells does have the same value !?
> i played around with the attribute field, to catch the required collumn
> 'data'. it seems that i got it as every cell has '-2' which matches only to
> this collumn.
> by the way, i casted my int data to float as v.surf.idw matches
> field='which decimal attribute'. is this redundant?
> GRASS 5.7.-cvs:~/diss/grassdata > v.surf.idw in=temp20000130180000
> out=temp20000130180000 field=4
> v.surf.idw:
> WARNING: Vector used instead of sites.
> Reading sites map (temp20000130180000) ... 6 sites loaded
> Interpolating raster map <temp20000130180000> ... 2800 rows ... done
> GRASS 5.7.-cvs:~/diss/grassdata > d.rast temp20000130180000
> 100%
> GRASS 5.7.-cvs:~/diss/grassdata > d.what.rast
> Buttons
> Left: what's here
> Right: quit
> 196272.91666667(E) 5215609.58333333(N)
> temp20000130180000 in sabine57, quant (-2)
> temp20000130180000 in sabine57, actual (-2.000000)
> 169731.25(E) 5184692.91666667(N)
> any advice welcome! thanks a lot.
> yours, sabine
